Control Center not opening (Erazer P60i laptop)
6 ANTWORTEN 6
luxe
Nachricht 1 von 7
1.562 Aufrufe
Nachricht 1 von 7
1.562 Aufrufe
The control center app randomly stopped opening and wont open. I've tried pressing Fn + Esc, opening it from the hidden icons menu, and restarting my laptop multiple times. Every time i try to open it the loading icon will flash for a split second and it wont open. Can anyone help me with this please. Thanks
6 ANTWORTEN 6
KudoPhant
Nachricht 2 von 7
1.483 Aufrufe
Nachricht 2 von 7
1.483 Aufrufe
I have the same issue (Deputy P60i). I found a temporary way to fix it by uninstalling and reinstalling the control center using its installer (restarting my laptop at each step as the installer advise you to).
But this solution only works until I shut down my laptop, then I have to do it all over again. Not sure if that really helps.
repoman
Nachricht 3 von 7
1.401 Aufrufe
Nachricht 3 von 7
1.401 Aufrufe
A few on here are having the sme problem (and many more will quite soon). It seems to be down to a driver update:
https://community.medion.com/t5/Applications/Issue-with-Windows-11-update-quot-CLEVO-System-6-0-91-1...
I found some further information
https://www.elevenforum.com/t/clevo-sager-control-center-3-0-v6-042-has-broken-a-few-days-ago-and-br...
I encounterd it after updating to Windows 11 24H2. It installed the offending update which prevented the Control Center UI opening.  I rolled back to Windows 11 23H2 and reinstalled Control Center which fixed the problem.
For a few days.  Today Control Center is refusing to open again.  I have gone through the steps of uninstalling and reinstalling.  The old versions of the ACPI bridge drivers described in the second link are insatlled, but still no access to the UI.  Although Control Center is running, I have lost my keyboard backlight setup and have no way to now change it that I am aware of/
I'm away from home and restricted as to what else I can try.  If all else fails, I have a clone of the hard from a few months ago and will try reverting to that and blocking all further updates pending further investigation.  I'll report back if nobody finds a fix, but it will be at least 2 weeks before I get a chance to look properly.
repoman
Nachricht 4 von 7
1.400 Aufrufe
Nachricht 4 von 7
1.400 Aufrufe
I'm on an E40, but it'll be the same issue.
Yuka
Nachricht 5 von 7
1.349 Aufrufe
Nachricht 5 von 7
1.349 Aufrufe
Im in a Crawler E30e and have the same problem.
romainht
Nachricht 6 von 7
1.063 Aufrufe
Nachricht 6 von 7
1.063 Aufrufe
Same problem for me (Deputy P60i)
repoman
Nachricht 7 von 7
1.057 Aufrufe
Nachricht 7 von 7
1.057 Aufrufe
We have a potential workaround
https://community.medion.com/t5/Applications/Control-Center-v6-009-broken-please-medion-fix-your-sof...
It doesn't fix the now broken Control Center, but does provide another way of getting at the settings - with a little work :~)
Good luck.
6 ANTWORTEN 6
