Control Center v6.009 broken, please medion fix your software kthx
8 REPLIES 8
Chromatic
Message 1 of 9
Message 1 of 9
Yo,
I bought a Medion Erazer Deputy P40 MD62551 a year ago and had no issue so far.
Until now where the control center (v6.009) just stops working when I try opening it. Decided to reinstall it but it just made it worse.
Please help me I'm going to lose my mind
1 ACCEPTED SOLUTION
carpediem
Message 5 of 9
Message 5 of 9
Hello @Chromatic ,
 i have found an alternativ in the microsoft store https://apps.microsoft.com/detail/9N6WG0G8B041?hl=neutral&gl=BE&ocid=pdpshare
install, restart and enjoy
with this i can control "power mode, fan speed, ect"
Carpediem
8 REPLIES 8
repoman
Message 2 of 9
Message 2 of 9
A number of people reporting this, and I suspect that that number will start to increase fast.  It seems to be down to an update, more details here:
https://community.medion.com/t5/ERAZER-Gaming/Control-Center-not-opening-Erazer-P60i-laptop/m-p/1757...
Let's hope for a quick fix, or workaround, once support staff get back from their holidays.
Chromatic
Message 3 of 9
Message 3 of 9
bro you are not helpful at all, all you do is just repeat the same WE ALL KNOW
repoman
Message 4 of 9
Message 4 of 9
Awesome. You replicate the question that "WE ALL KNOW", I try to help by spreading what little information there is and pulling folks together, and get abuse.
carpediem
Message 5 of 9
Message 5 of 9
Hello @Chromatic ,
Carpediem
repoman
Message 6 of 9
Message 6 of 9
Oh wow - that does appear to work.  I had to grab LEDs Keyboard Setting - Free download and install on Windows | Microsoft Store in order to get to the keyboard backlight settings, but it looks like a useful jump off point.  Thank you!
Chromatic
Message 7 of 9
Message 7 of 9
Wow I never knew the existence of CC in microsoft store lmao, thanks that kinda fixes the issue
Xerox
Message 8 of 9
Message 8 of 9
This error is due to the LATEST Win 11 Build update.
Issue resolved after uninstalling update
Go to settings > Windows Update > Recovery > Revert Update.
My issue is resolved after following these steps.
Additionally, switch off auto updates by by pressing Win+R > type "services.msc" > scroll down to Windows update > Disable it
Hope it helps!
Tags (1)
ssalter772
Message 9 of 9
Message 9 of 9
Same issue for me, Erazer Crawler E50, disappeared recently, cannot get to work after having uninstalled, then reinstalled, key shortcuts not working, it's like it doesn't exist, I can't find it anywhere.
8 REPLIES 8
