Brand new p15603 FAN going crazy
13 REPLIES 13
mperus
Message 1 of 14
Message 1 of 14
Just bought it and am at the point of installing software - Office 365, VLC and stuff and fan is constantly at 80 % or more, which is VERY loud. What to do ? I cant even imagine what will happen when i try an actual game.
13 REPLIES 13
Gehringer
Retired
Message 11 of 14
Message 11 of 14
HI @mperus ,
please get in touch with support services to let the technicians to take a look at your PC.
They will do everything they can to have this problem solved.
Regards,
Gehringer
mperus
Message 12 of 14
Message 12 of 14
would do that already, but cant really afford that now with all the work from home.
Gehringer
Retired
Message 13 of 14
Message 13 of 14
Hi @mperus ,
I understand it.
Our technical team will be available whenever you need us.
Regards,
Gehringer
jackjiang2020
Message 14 of 14
Message 14 of 14
Hi, you can check the air outlet. If it is blocked, there will be heat dissipation problems, and the CPU temperature will be very high. At this time, the system will automatically increase the fan speed.
13 REPLIES 13
