Blue Screen DRIVER_IRQL_NOT_LESS_OR_EQUAL, kbdclass.sys
6 RÉPONSES 6
paulmaindivide
Message 1 sur 7
8 022 Visites
Message 1 sur 7
8 022 Visites
Hello
I recently bought a Medion Erazer Deputy P40, without OS. I installed Windows 11 on it, as well as the drivers I downloaded from the manufacturer's website https://www.medion.com/gb/service/product-detail/30035597. The computer reference is MSN: 30035597.
Since the first weeks of use, the computer crashes with a blue screen and the reason is as follows: DRIVER_IRQL_NOT_LESS_OR_EQUAL, and the sub-reason is: kbdclass.sys
The problem occurs regularly every 1h-3h (it depends) when I play.
Has anyone ever encountered this problem, and if so how to fix it please? I hesitate to return the computer and exchange it for another brand.
1 SOLUTION APPROUVÉE
Solutions acceptées
paulmaindivide
Message 4 sur 7
7 817 Visites
Message 4 sur 7
7 817 Visites
Hello everyone,
I found a solution thanks to a post I did in tom's hardware forum : https://forums.tomshardware.com/threads/bdos-driver-irql-not-less-or-equal-kbdclass-sys.3825937/
I had to modify the registry to remove a certain driver. Someone explained step by step how to do it, for everyone with the same issue as mine I invite them to follow the thread.
Thanks
6 RÉPONSES 6
Message 2 sur 7
8 012 Visites
Message 2 sur 7
8 012 Visites
Hi,
@paulmaindivide
This sounds like a keyboard problem
Did you decompress the zip- file first and  put the files in a separate folder?
Only from there you can install the drivers.
2. have you already upgraded the Bios?
3. And the Control Center software also?
If nothing hselp you have to redo the installation.
How did you install?
The best would be with the Media Creation Tool, and without an Internet connection. Upgrading everything is better be done after Windows is primarily installed first and functional.
Bye, daddle
paulmaindivide
Message 3 sur 7
7 981 Visites
Message 3 sur 7
7 981 Visites
Hello @daddle thanks for your reply
I decompressed the important drivers folders (control center, chipset, nvidiavga, lan), and I installed them.
I haven't upgraded the bios though, how can I do it ?
And yes I installed the control center. I also tried to uninstall it an reinstall it. I've read in some forums the cause would be one of the file that comes with it. I wanted to make a test and uninstall the control center and see if it still happens. What would be the risk of that ? Thanks
paulmaindivide
Message 4 sur 7
7 818 Visites
Message 4 sur 7
7 818 Visites
Hello everyone,
Thanks
Message 5 sur 7
7 814 Visites
Message 5 sur 7
7 814 Visites
@paulmaindivide
Thanks for the feedback. Quite interesting. Medion should react to this.
One question, your keyboard or clickpad (touchpad) is still functional?
Thanks, daddle
paulmaindivide
Message 6 sur 7
7 812 Visites
Message 6 sur 7
7 812 Visites
Yes everything is still working
Houssem
Message 7 sur 7
3 924 Visites
Message 7 sur 7
3 924 Visites
they absolutely should i don't why they ignore this, i'm thinking about doing a refund now
6 RÉPONSES 6
