Bios request for erazer x17805
3 REPLIES 3
Erazerx1
Message 1 of 4
Message 1 of 4
MSN is 30027602
My bios wont open up after some tweaking..
I can only change boot devices and the rest wont even open...
I need the bios .rom or .bin file i need to reflash it.
Tags (1)
3 REPLIES 3
sylviareidvqee
Message 2 of 4
Message 2 of 4
A BIOS password is a security precaution that requires a computer user to log into the machine's basic input/output system (BIOS) before a computer will boot up.
aessuccess
Gehringer
Retired
Message 3 of 4
Message 3 of 4
Hi @Erazerx1 ,
First, I need you to be aware that flashing your BIOS is a sensitive procedure that may cause your unit to be useless, if it fails. Therefore, Medion can't recommend you to do it, nor assume any responsibility for the consequences of your act.
That said, you can find here the link for current BIOS version N 1.54.
The .zip file has a Winflash Update including the GK7CP7SN154.ROM you are looking for.
Regards,
Gehringer
Erazerx1
Message 4 of 4
Message 4 of 4
Hey @Gehringer !
The file worked and i flashed it but i need an older version of the bios, i would appreciate it alot!
3 REPLIES 3
