Add ram in erazer p6661
10 REPLIES 10
sybes
Message 1 of 11
Message 1 of 11
Hello, I have an erazer p6661.
I would like to know if it is possible to add another ram ?
I have already a 6go ram but it is not enough.
Cordially
1 ACCEPTED SOLUTION
TPFLegionaire
Retired
Message 4 of 11
Message 4 of 11
Hi @sybes
this model has indeed 6GB of ram but will accept 16GB, 2 stick of 8 GB would do it or 2 of 4GB if your budget does not stretch to that yet.
RAM:
1x 2048 MB DDR3 SO-DIMM (PC3-12800 / 1600 MHz)
1x 4096 MB DDR3 SO-DIMM (PC3-12800 / 1600 MHz)
(1/2 slots; 16 GB max.)
Let me know if there is anything else we can do for you.
Cheers!
TPFLegionaire
MEDION AG - A Lenovo Company • • Community: community.medion.com
Please reward helpful posts with Kudos and mark solutions with Accept as solution.
10 REPLIES 10
TPFLegionaire
Retired
Message 2 of 11
Message 2 of 11
Hi @sybes
Welcome to the forums!
Could you give me the MSN number (8 digits ) of your machine (on the back)  this will ensure i look at the right specs before giving you some advice.
Also, how many ram modules do you have currently installed and which OS  (32 or 64 bits ) are you using?
Cheers!
Cheers!
TPFLegionaire
sybes
Message 3 of 11
Message 3 of 11
Hello,
The MSN is : 30019951.
Currently, I have 6go.
Currently, I have 2 modules.
And I have a windows 10 64bits
TPFLegionaire
Retired
Message 4 of 11
Message 4 of 11
Hi @sybes
RAM:
Cheers!
TPFLegionaire
sybes
Message 5 of 11
Message 5 of 11
Thank you for your answer.
Do you know if is it possible to have one stick with 3go and 1 stick with 8go ?
sybes
Message 6 of 11
Message 6 of 11
And is it possible for example, to have 2 sticks with 16 Go for each ? (2x16 = 32 Go)
sybes
Message 7 of 11
Message 7 of 11
An other question :
Is it compatible with this ram ? : ballistix so-dimm DDR4 8Go 2400MHz CL16 SR ?
TPFLegionaire
Retired
Message 8 of 11
Message 8 of 11
hi @sybes
I am not familiar with the existence of a 3GB stick of DDR3 RAM, if there was one, only experimentation with that 8 GB RAM would tell you for sure if it worked.
As for your other question, this particular machine only support up to 16GB of RAM, 2 sticks of 8GB would be ideal.
if you have 2 sticks of 16GB handy to try, you could see if it worked but at your own risks.
Can you tell us a little bit more about your intended use , any particular software that would require this much RAM?
Cheers!
TPFLegionaire
sybes
Message 9 of 11
sybes
Message 10 of 11
Message 10 of 11
It will be used to made hard calculation and use Android Studio with Intel HAXM acceleration with virtual device and chrome at the same time for example. And 6 Go is not enough for all of that.
10 REPLIES 10
