swapping psu - hidden screws?
5 ANTWOORDEN 5
Geordio
Bericht 1 van 6
1.365 Weergaven
Bericht 1 van 6
1.365 Weergaven
Hi, I have an Akoya E32014 and want to stick in a GPU, so I'm going to upgrade the PSU too. I have removed the 4 screws on the back of the case but the PSU still seems to be fixed into the case somehow - it's not just sliding out. Is there a hidden screw somewhere that I'm missing? Is the psu meant to be swapped out from this model or have they fixed it in on purpose so it can't be removed? You can't take the other side of the case off to check. Any help gratefully received, thanks.
1 GEACCEPTEERDE OPLOSSING
Geaccepteerd Solutions
Bericht 2 van 6
1.345 Weergaven
Bericht 2 van 6
1.345 Weergaven
Hello @Geordio and welcome.
If I understand correctly, you have to push the locking bracket in to slide the power supply inward after removing the four screws on the back.
bye Fishtown
5 ANTWOORDEN 5
Bericht 2 van 6
1.346 Weergaven
Bericht 2 van 6
1.346 Weergaven
bye Fishtown
Geordio
Bericht 3 van 6
1.342 Weergaven
Bericht 3 van 6
1.342 Weergaven
thanks, yes, I found that already. Thanks for confirming though!
mitko
Bericht 4 van 6
258 Weergaven
Bericht 4 van 6
258 Weergaven
could you tell me can i upgrade the psu with 750 w corsair ,where to find that motherboard 24 to 14 pin adapter
Bericht 5 van 6
252 Weergaven
Bericht 5 van 6
252 Weergaven
Hello @mitko and welcome.
The E32014 computer has a B460 motherboard which has a 24-pin connector. What do you need a 14-pin connector for?
bye Fishtown
mitko
Bericht 6 van 6
225 Weergaven
Bericht 6 van 6
225 Weergaven
Motherboard is H110H4-EM2 wih 14 pin atx plug , 3 pins are empty,i already ordered 24 to 14 pin atx adapter for ibm/lenovo ,will be like diy till i check it with voltmeter.I need to upgrade the psu with cx750m ,i hooked 1080 sc and 6 hdd,  i wil buy new case for all that stuff
5 ANTWOORDEN 5
