swapping psu - hidden screws?
5 RÉPONSES 5
Geordio
Message 1 sur 6
1 666 Visites
Message 1 sur 6
1 666 Visites
Hi, I have an Akoya E32014 and want to stick in a GPU, so I'm going to upgrade the PSU too. I have removed the 4 screws on the back of the case but the PSU still seems to be fixed into the case somehow - it's not just sliding out. Is there a hidden screw somewhere that I'm missing? Is the psu meant to be swapped out from this model or have they fixed it in on purpose so it can't be removed? You can't take the other side of the case off to check. Any help gratefully received, thanks.
1 SOLUTION APPROUVÉE
Solutions acceptées
Message 2 sur 6
1 646 Visites
Message 2 sur 6
1 646 Visites
Hello @Geordio and welcome.
If I understand correctly, you have to push the locking bracket in to slide the power supply inward after removing the four screws on the back.
bye Fishtown
5 RÉPONSES 5
Message 2 sur 6
1 647 Visites
Message 2 sur 6
1 647 Visites
bye Fishtown
Geordio
Message 3 sur 6
1 643 Visites
Message 3 sur 6
1 643 Visites
thanks, yes, I found that already. Thanks for confirming though!
mitko
Message 4 sur 6
559 Visites
Message 4 sur 6
559 Visites
could you tell me can i upgrade the psu with 750 w corsair ,where to find that motherboard 24 to 14 pin adapter
Message 5 sur 6
553 Visites
Message 5 sur 6
553 Visites
Hello @mitko and welcome.
The E32014 computer has a B460 motherboard which has a 24-pin connector. What do you need a 14-pin connector for?
bye Fishtown
mitko
Message 6 sur 6
526 Visites
Message 6 sur 6
526 Visites
Motherboard is H110H4-EM2 wih 14 pin atx plug , 3 pins are empty,i already ordered 24 to 14 pin atx adapter for ibm/lenovo ,will be like diy till i check it with voltmeter.I need to upgrade the psu with cx750m ,i hooked 1080 sc and 6 hdd,  i wil buy new case for all that stuff
5 RÉPONSES 5
