iGPU not detected
2 REPLIES 2
iGPR3
Message 1 of 3
Message 1 of 3
iGPU not detected
Hi. I have a medion PC that I bought a few years ago. It has a 2060 super and i5-10400, which SHOULD have an iGPU. Its (i believe) a BH460H6-EM motherboard or something like that. Does anybody know what key the BIOS is or if there is any other way to enable the iGPU? Task manager doesnt show it and its definitely a 10400 and not a 10400F. Thanks in advance, all help is appreciated.
EDIT: I got into the BIOS via windows troubleshooting options. The BIOS sees it as an i5-10400, so there should be an iGPU, but there is nothing that mentions enabling/disabling it..
EDIT 2: I found the setting, it said that IGD was disabled, so I re-enabled it and it’s recognised in windows now.
2 REPLIES 2
Mallia
Message 2 of 3
Message 2 of 3
Hi @iGPR3
Why not share the steps you took to resolve the issue here for everyone to benefit from? 👍
Message 3 of 3
Message 3 of 3
@Mallia
You should have read Edit 2 in  @iGPR3s Post!   😉
Regards, daddle
2 REPLIES 2
