bios key for All in one PC E23401 30026003
1 ANTWORT 1
DiMoll
Visitor
Nachricht 1 von 2
4.993 Aufrufe
Nachricht 1 von 2
4.993 Aufrufe
Help Please,
Im trying to alter the boot sequence on my All in one PC.  Ive tried holding Delete, F1, F2,F3, F12
 I cannot get in at all. I hate Windows 10 and want to install Labuntu
Please Help
DiMoll
Tags (1)
1 ANTWORT 1
Nachricht 2 von 2
4.991 Aufrufe
Nachricht 2 von 2
4.991 Aufrufe
@DiMoll
Tap rythmically the F2 key.  immediately after switching the PC on.
Another method  is, to make use of th F10 Key, then you get the Boot Menu on the Screen. The  lowest entry "Setup" lets yoiu enter the UEFI Settings as well.
And I know what I am talking about, my wife has exactly the same PC here, which functions perfect.
For leaving Windows press and hold the shift tab, than choose Run down with the shift key still pressed.
After that  if you restart with F2 pressed ( or with F10 ) you can enter bios (UEFI) again.
Sometimes, when Windows has to finish an Update when starting the machine, it will not work.
Then just redo the procedure.
In UEFi on the page Boot I would deactivate Quiet Boot. Than you see for a short time after switching on the Bios LOGO, and underneath in white letters ->  Press F2 for Bios, and F10 for the Boot menu.
But this appears  immediately after switching on, so you also can immediately after switching on pressing or tapping the F2 or the F10 key.
Cheers, daddle
1 ANTWORT 1
