No Signal on screenpo
4 ANTWOORDEN 4
Nekoriran
Bericht 1 van 5
12.643 Weergaven
Bericht 1 van 5
12.643 Weergaven
I started my medion desktop MEDION AKOYA P7385 D (MD 8883) up and I got only NO SIGNAL message on screen.
I have tested it with an other monitor, sam result. I pluged power cable out, pressen on botton for 15 sec and powerd on again, same result. I have got battery bios battery for 5 min out and again in, same result.
When it was working after setting on fan began to work for a while and stopped and after that logon page on screen but fan keeps working with loudly sound and I get NO signa on screen. What's the problem with my computer? Please help
1 GEACCEPTEERDE OPLOSSING
Geaccepteerd Solutions
Bodgekin
Bericht 2 van 5
14.433 Weergaven
Bericht 2 van 5
14.433 Weergaven
Hi @Nekoriran
No signal usually points to a problem with the monitor, cable, or inside the PC with the motherboard or graphicscard. When you tested the other monitor, did you also use a different cable? If so, I'm afraid that either your motherboard or graphicscard is defective :(.
Kind regards,
Bart
4 ANTWOORDEN 4
Bodgekin
Bericht 2 van 5
14.434 Weergaven
Bericht 2 van 5
14.434 Weergaven
Hi @Nekoriran
Kind regards,
Bart
Nekoriran
Bericht 3 van 5
12.197 Weergaven
Bericht 3 van 5
12.197 Weergaven
Thanks a lot for your advise, I have replaced grafic card and my computer works good again.
Bodgekin
Bericht 4 van 5
12.079 Weergaven
Bericht 4 van 5
12.079 Weergaven
Your welcome :), glad to hear your PC is fixed!
Kind regards,
Bart
Faz
Bericht 5 van 5
11.438 Weergaven
Bericht 5 van 5
11.438 Weergaven
I too have the the problem.  I have tested the monitor and cable on another PC, it worked.  I have tried another working monitor on the Medion PC and it did not work, i got the same error on a blue rectangle box, "No Signal".  Now here i the odd one.  I have just powered off and on and this time i got the single bleep as it started up.  This time it went throught boot up, F11 screen etc and launched windows 10.  Is obviously and intermittant fault, but how do i find out what?
4 ANTWOORDEN 4
