Motherboard ECS B360H4-EM What revision are suitable processors ?
8 REPLIES 8
GoodPoti
Message 1 of 9
Message 1 of 9
On the configuration page it says that the 6,7,8,9 generation of processors. But I install i3 6100 and it doesn't start. But with the i5 8600 everything works. So all the same, what generations of processors are suitable? Please help
8 REPLIES 8
EastClintwood
Message 2 of 9
Message 2 of 9
Hi @GoodPoti, and welcome to the community.
If you have the opportunity, it would be good to test the i3 6100 on another motherboard so that a defect can be ruled out.
Is the i3 processor not recognised at all or how does the problem occur?
Greetings,
EastClintwood
GoodPoti
Message 3 of 9
Message 3 of 9
i3 6100 is OK. The board is loaded three times restarted, the fan is loaded 4 times and weighs like that. Doesn't go into bios.
GoodPoti
Message 4 of 9
Message 4 of 9
I will buy i3-7100, i3 6100 will return to the store. After checking the i3 7100 I will write to you
EastClintwood
Message 5 of 9
Message 5 of 9
Hello @GoodPoti,
Thanks for the information.
I am waiting for your reply.
EastClintwood
GoodPoti
Message 6 of 9
Message 6 of 9
i3 7100 won't start at all. Starts and turns off after 1 second.
EastClintwood
Message 7 of 9
Message 7 of 9
Hello @GoodPoti,
The i5 processor 8600 is still working fine for you?
We have passed this on to the relevant department and will get back to you as soon as we have received feedback.
Regards,
EastClintwood
GoodPoti
Message 8 of 9
Message 8 of 9
i5 8600 works without any problems
GoodPoti
Message 9 of 9
Message 9 of 9
Delivered G5400 (8th generation) everything works. 6-7 generation does not work.
8 REPLIES 8
