Medion Erazer p10 x31 i7 freezing
5 RÉPONSES 5
Aty
Message 1 sur 6
2 463 Visites
Message 1 sur 6
2 463 Visites
Hi,
I have a Medion Erazer PC. I believe it is the engineer Pro p10 x31.  It is the i7 12700 with the 3060ti running Windows 11.
The pc will freeze quite often.
The pc has the gigabyte B660M DS3H Motherboard. I've updated all the drivers etc with no luck in resolving the problem.
The bios is showing a 100, how do I update the bios to the latest version as the gigabyte firmware cannot be installed.
5 RÉPONSES 5
Aty
Message 2 sur 6
2 350 Visites
Message 2 sur 6
2 350 Visites
MSN is 10024811
carter90
Message 3 sur 6
2 259 Visites
Message 3 sur 6
2 259 Visites
hi there did you get this problem solved ? im also looking to up date the bios im currently on 101mg but there is no info to inform me if my current bios supports 13th gen intel CPUs
thanks in advance.
Aty
Message 4 sur 6
2 230 Visites
Message 4 sur 6
2 230 Visites
Hi,
I have had no reply or solution.
To be honest I'm really disappointed by the support, if this the official channel for support then I won't be buying another Medion product in the future.
carter90
Message 5 sur 6
2 218 Visites
Message 5 sur 6
2 218 Visites
I’ve called the helpline and spoke to an agent that didn’t have a clue what I was taking about and was advised to reinstall windows 🤦‍♂️ tried to explain the situation with the bios and was told to email my problem to the Medion help desk that was 6 days ago, felt like the call centre was totally incompetent and inexperienced.
Aty
Message 6 sur 6
2 208 Visites
Message 6 sur 6
2 208 Visites
The best solution to date was to use the Nvidia studio drivers after a full system reset and restore
However the bios question still goes unanswered.
What phone number did you call?
5 RÉPONSES 5
