Medion Erazer p10 x31 i7 freezing
5 ANTWORTEN 5
Aty
Nachricht 1 von 6
2.445 Aufrufe
Nachricht 1 von 6
2.445 Aufrufe
Hi,
I have a Medion Erazer PC. I believe it is the engineer Pro p10 x31.  It is the i7 12700 with the 3060ti running Windows 11.
The pc will freeze quite often.
The pc has the gigabyte B660M DS3H Motherboard. I've updated all the drivers etc with no luck in resolving the problem.
The bios is showing a 100, how do I update the bios to the latest version as the gigabyte firmware cannot be installed.
5 ANTWORTEN 5
Aty
Nachricht 2 von 6
2.332 Aufrufe
Nachricht 2 von 6
2.332 Aufrufe
MSN is 10024811
carter90
Nachricht 3 von 6
2.241 Aufrufe
Nachricht 3 von 6
2.241 Aufrufe
hi there did you get this problem solved ? im also looking to up date the bios im currently on 101mg but there is no info to inform me if my current bios supports 13th gen intel CPUs
thanks in advance.
Aty
Nachricht 4 von 6
2.212 Aufrufe
Nachricht 4 von 6
2.212 Aufrufe
Hi,
I have had no reply or solution.
To be honest I'm really disappointed by the support, if this the official channel for support then I won't be buying another Medion product in the future.
carter90
Nachricht 5 von 6
2.200 Aufrufe
Nachricht 5 von 6
2.200 Aufrufe
I’ve called the helpline and spoke to an agent that didn’t have a clue what I was taking about and was advised to reinstall windows 🤦‍♂️ tried to explain the situation with the bios and was told to email my problem to the Medion help desk that was 6 days ago, felt like the call centre was totally incompetent and inexperienced.
Aty
Nachricht 6 von 6
2.190 Aufrufe
Nachricht 6 von 6
2.190 Aufrufe
The best solution to date was to use the Nvidia studio drivers after a full system reset and restore
However the bios question still goes unanswered.
What phone number did you call?
5 ANTWORTEN 5
