Medion Erazer Recon P20 RAM and SSD
11 ANTWOORDEN 11
plutissimo
Bericht 1 van 12
154.146 Weergaven
Bericht 1 van 12
154.146 Weergaven
Hi,
I have bought a Medion Erazer Recon P20 MD35348 and would like to upgrade the RAM and add an SSD. I have read plenty of threads in this community and from what I understand you have to be very careful to buy something that is compatible. However, I cannot seem to find information about exactly what is compatible. Can anyone please help with what the requirements are?
Stock configuration as I understand it:
- Intel B660 chipset
- 8 GB DDR4 PC3200 RAM
- 512 GB SSD M.2
- MSN: 10024815
I would primarily like to buy another 8GB RAM module that matches the existing in the spec, but if that doesn't work two new RAM modules that are compatible with the motherboard.
Thanks!
Tags (4)
11 ANTWOORDEN 11
plutissimo
Bericht 11 van 12
69.759 Weergaven
Bericht 11 van 12
69.759 Weergaven
OK. Thx.
/plutissimo
plutissimo
Bericht 12 van 12
131.830 Weergaven
Bericht 12 van 12
131.830 Weergaven
For anyone else interested in adding another 8 GB RAM to the existing, I can confirm that another RAM-module with CAS22, 1.2 volt works well to get dual channel 16 GB in total (2x8GB).
The stock Hynix memory module is outdated and cannot be bought, but a standard memory like the "Crucial RAM CT8G4DFRA32A 8GB DDR4 3200MHz CL22" (available at Amazon) works with the pre-installed one.
It all runs on dual channel 1600 MHz, so 3200 MHz in total. See below.
11 ANTWOORDEN 11
