Medion Akoya pc e63003 graphic card
1 REPLY 1
lsdiwana
Message 1 of 2
Message 1 of 2
hi
I had recently purchased this pc from Aldi, as in the CPU there are only HDMI and DP port.
I am looking to upgrade the graphic card with more video output as I work on  multi screen. just want to see if anyone in the forum had done it before and suggestions would be appreciated.
1 REPLY 1
Gehringer
Retired
Message 2 of 2
Message 2 of 2
Hi @lsdiwana and welcome to the FORUM!
Can you please let us know the MSN number of your product?
It is an 8-digits number that you can find printed on a label underneath it. It usually starts by 100, 300 or 500.
Regards,
Gehringer
1 REPLY 1
