Medion AKOYA P4375 D RAM upgrade help
3 RÉPONSES 3
SirPen
Message 1 sur 4
5 427 Visites
Message 1 sur 4
5 427 Visites
Hi fellows nerds.
Im trying to upgrade my RAM fra 2x2 GB to 2x8 GB
My specs are:
i3 processor 3,2GHz
win 7 home premium 64.
My BIOS is from 2010 and I would think that it is the problem I face.
Is there any way to get an update to my bios?
Thanks.
3 RÉPONSES 3
Message 2 sur 4
5 420 Visites
Message 2 sur 4
5 420 Visites
@SirPen, Welcome to the ccommunity.
Checking out your PC at the german service pages and looking into the manual on page 44 (which you should have also, accompanying your PC), it says only 2x 4gb are supported.
The mainboard has 2 DIMM-sockets, for maximum 4 GB each
The BIOS automatically senses the modules size, type and speed .
Specs.:
 240-pin DIMMs with 1333 MHz / 1066 MHz
 DDR3 (unbufferd), 1.5 V
 Single- oder Double-Sided DIMM. The mainboard may be equipped with modules of different sizes, but only with identical speed (frequencies).
For optimal performance make use of the slots in following order:
 DIMM_1 + DIMM_2
Regards, daddle
SirPen
Message 3 sur 4
5 411 Visites
Message 3 sur 4
5 411 Visites
Thanks Daddle.
Had more or less come to the same conclusion but nice to get it confirmed.
Message 4 sur 4
5 408 Visites
Message 4 sur 4
5 408 Visites
@SirPen
Nope, these things you can not concluden or guess, you have to know. Means you have to get the information from a validated source. Like the manual, so RTFM! Smiley clignant de l'œil
3 RÉPONSES 3
