Medion AKOYA P3605D PC Win 11 upgrade
4 RÉPONSES 4
MuadDib
Message 1 sur 5
2 540 Visites
Message 1 sur 5
2 540 Visites
I have a Medion AKOYA P3605D PC with Win10 operating system. I would like to upgrade it to Win11. I did check wiith PC Health program, tham my processor ( AMD Ryzen 5-1500X ) is not compatible with Win11. So I bought a AMD Ryzen 5-2600X which should be.
When I tried to start with the new processor the system did not load at all. My questions are:
1. Does this motherboard (Medion P2A4-EM ver.1.0) supports my new processor?
2. If yes, do I need to update the bios or do I need to do anything else to make them work?
3. If the bios needs to be updated, where can I find a newer version and how can I update it?
I would be thankfull for any advise in this topic since the support of Win10 will be finished soon. Thanks.
4 RÉPONSES 4
Message 2 sur 5
2 537 Visites
Message 2 sur 5
2 537 Visites
Hello @MuadDib and welcome
Actually it should work.
Is this your computer? https://www.medion.com/gb/service/product-detail/10021776
Then you have an ECS P2A4-EM/B350 board that can handle a CPU with up to 95 watts. https://community.medion.com/t5/kb/en/ta-p/138828
The chipset is also OK B350/X370 and the 5-2600x has 95 watts.
https://versus.com/de/amd-ryzen-5-1500x-vs-amd-ryzen-5-2600x
So there is nothing against it. Was this a new or used CPU?
bye Fishtown
Edit : Bios Update :https://www.medion.com/en/servicebackend/_lightbox/software_details.php?did=17431
MuadDib
Message 3 sur 5
2 533 Visites
Message 3 sur 5
2 533 Visites
Hi, thanks for the quick reply. Yes I think this is my PC. It is good to know that it should work without any problem. The new CPU is a used one. do you think it is damaged?
Message 4 sur 5
2 528 Visites
Message 4 sur 5
2 528 Visites
Hello @MuadDib ,
I read further and there are some posts that only the first generation is supported by this board.
The information in the FAQ may not be correct.
bye Fishtown
MuadDib
Message 5 sur 5
2 513 Visites
Message 5 sur 5
2 513 Visites
Wow, thanks for your help. This is not a good news. If you were right than I have no chance to upgrade my Windows  to 11.
4 RÉPONSES 4
