MEDION ERAZER ENGINEER P10 (MD35007)
2 ANTWORTEN 2
ridensuto
Nachricht 1 von 3
1.632 Aufrufe
Nachricht 1 von 3
1.632 Aufrufe
Hi, the graphic card that came with this computer does not work any more. For some reason. But the pc works fine with a new grapics card. My kind wife got me a new RTX 3060 graphics card for christmas. And my question is, does the motherboard on my modell: MD35007 support PCI express port 3 or 4? And can still use a graphics card that support PCI express 4 on it? Will the graphics look terrible or great? Cant compare to my old one that did not work as it should.
Tags (1)
2 ANTWORTEN 2
Nachricht 2 von 3
1.628 Aufrufe
Nachricht 2 von 3
1.628 Aufrufe
@ridensuto
Hi. Your graphic card will work anyway, because they are backwards compatible.
Your Mainboard is a B460H6-EM. So if you check with Intel, you will find the technical data for the B460 chipset.
Regards, daddle
ridensuto
Nachricht 3 von 3
1.626 Aufrufe
Nachricht 3 von 3
1.626 Aufrufe
Thanks for the answer as always 🙂
2 ANTWORTEN 2
