MEDION AKOYA P66029 no case fan
3 REPLIES 3
divi
Message 1 of 4
Message 1 of 4
Hi!
I have been about to buy MEDION AKOYA P66029, but it doesn't have any case fans. It has 2x gpu-fan, 1x cpu-fan, 1x psu-fan, 0x case-fan.
What should I think of this? And is it possible to install there a case-fan without changing the factory PSU and without expiring the warranty (that's 2 years here). It sounds insane to me that there is no case-fan at all.
1 ACCEPTED SOLUTION
Gehringer
Retired
Message 4 of 4
Message 4 of 4
Hi @divi ,
it does not look like an issue with your product.
Regards,
Gehringer
3 REPLIES 3
Gehringer
Retired
Message 2 of 4
Message 2 of 4
Hi @divi ,
the case is well opened and ventilated.
If you perform any physical modification on the product, I would assume your warranty is voided.
Regards,
Gehringer
divi
Message 3 of 4
Message 3 of 4
I ended up buying the product anyways. But is this intentional that there is no case fan or is there some mistake in the product that it would miss a fan that should be there? Its still quite high end gaming pc with i5-8400 and 8 Gt GTX 1070.
Gehringer
Retired
Message 4 of 4
Message 4 of 4
Hi @divi ,
Regards,
Gehringer
3 REPLIES 3
