MEDION AKOYA P4375D. Moederbord MS-7708 How I connect the wires on the motherboard
2 RÉPONSES 2
Tony
Message 1 sur 3
4 187 Visites
Message 1 sur 3
4 187 Visites
I don't mean the 12V wiring, the SATA or IDE wiring,
I mean the thin trigger with 4 pins and 1 blind.
I'm also looking for a scheme of the motherboard with the explanation of the components / jumpers.
2 RÉPONSES 2
Anu
Scientist
Message 2 sur 3
4 166 Visites
Message 2 sur 3
4 166 Visites
Hi @tony,
I've not been able to find any schemes or manuals for this motherboard, perhaps you can upload some pictures of the connectors and the available pins on the motherbord, usually there should be some sort of description on the connector and on the motherboard which we might be able to decipher 🙂
Groetjes,
Anu
Message 3 sur 3
4 150 Visites
Message 3 sur 3
4 150 Visites
@Tony
Sommige moederboord (of graphic cards) hebben een additional stroomverzorging voor de processor nodig, daarvoor is er een surplus steekkontakt op de MoBo (of graphic card). Maar niet iedere moederboord (graphic card) maakt er gebruik van, dus blijft de als jij het noemt "thin trigger with 4 pins and 1 blind" ongenut.
groetjes, daddle
2 RÉPONSES 2
