MEDION AKOYA E32013 Wont Boot
1 ANTWORT 1
sixxxpaths
Nachricht 1 von 2
2.022 Aufrufe
Nachricht 1 von 2
2.022 Aufrufe
Hello
I changed a setting in the BIOS for the memory to run at 3000mhz instead of the default 2666mhz, I then saved the changes and proceeded to restart the PC.
Now the PC just (long) beeps 3 times and does nothing else, No Video Output at all. The fans and HDD spin.
I have tried clearing the CMOS using the jumper and have also removed the battery for 24 hours but it has made no difference.
I have tried different RAM sticks but same issues occur.
Is there a way to flash a fresh BIOS without having access to the BIOS or Windows?
Thanks in advance
1 ANTWORT 1
Mastermind
Nachricht 2 von 2
2.003 Aufrufe
Nachricht 2 von 2
2.003 Aufrufe
Hi @sixxxpaths ,
already answered your post in the EN Community, so this one will be closed.
Cheers
1 ANTWORT 1
