CPU upgrade AKOYA P5390
9 REPLIES 9
goodmorninggood
Message 1 of 10
Message 1 of 10
Hello - I have an old ‘MEDION® AKOYA P5390 DR Multitasking Desk’, still runs pretty well, but wanted to look at upgrading the CPU.
I can’t find any information about the motherboard let alone a manual with compatible CPUs - the motherboard model number is
H110H4-CM2.
Does anyone have any advice?
1 ACCEPTED SOLUTION
Message 10 of 10
Message 10 of 10
Infos to ECS H110H4-CM2_DDR3L S1151 IPO W10 / MSN 20059419
Processor Support
Socket LGA 1151
Chipset
Intel GL82H110
USB 3.0 Controller
Intel integrated
USB
2 internal USB3.0 ports
2 USB 3.0 Back Panel Connectors
2 USB 2.0 Back Panel Connectors
Memory Support
DDR3L 1333 / 1600 MHz (16 GB Max)
2 DDR3L DIMMs (240pin / 1.35V only)
Single / Dual channel mode
Network
LAN: 10/100/1000 Fast Ethernet by Realtek RTL8111GN
WLAN: ./.
IEEE1394: ./.
Audio
6 channels audio codec Realtek ALC662-VD
1 x Front line out (green) / 1 x Line IN (blue) / 1 x Microphone in (pink)
Serial ATA
M.2(2260 and 2280 size with flexible standoff, only SATA mode supported)
Serial ATA: 3 x SATA III ports (black color)
BIOS
BIOS Manufacturer: AMI EFI BIOS APTIO core (new EFI)
BIOS Version: 110H4W0X.1xx (Medion specification)
BIOS Type: SPI flash (64Mbit)
Back panel: 2 x USB 2.0 / 2 x USB 3.0 / 1 x LAN (RJ45) / 1 x VGA output /  1 x HDMI output
On-Board Pinheaders:
1 x CPU 4PIN Fan header, CPU_FAN
1 x System Fan header, SYS_FAN
1 x Front Audio, F_AUDIO with purple plastic header
1 x Frontside USB :F_USB1 with Yellow plastic header
1 x Frontside USB :F_USB2 with black plastic header
1 x USB3.0 H10x2 front header F_USB30 (Intel pin out)
1 x Front_Panel header, F_PANEL black plastic header, 1 x 4PIN ATX 12V connector, ATX_12V
1 x 24PIN ATX connector "ATX_POWER"
1 x SPI, SPI_DEBUG
Slots
1 x PCIe x16
2 x PCIe x1
Abmessungen / Gewicht
Form Factor: Micro-ATX
Looks good according to the database:
the I7-6700K (CPU Intel Core i7-6700K 4,0 GHz)
it was installed in the board H110H4-CM2, see here:
bye Fishtown
9 REPLIES 9
mats749
Message 2 of 10
Message 2 of 10
Hi @goodmorninggood
And welcome to the community!
Please can you provide me with the MSN number of the product so that I can check that for you.
Thanks
Mats749
goodmorninggood
Message 3 of 10
Message 3 of 10
Removed wrong info
Message 4 of 10
Message 4 of 10
Hello and welcome
Unfortunately, that's the serial number. the MSN number is usually attached under the device. tilt it and look there.
Bye Fishtown
goodmorninggood
Message 5 of 10
Message 5 of 10
Removed info
Message 6 of 10
Message 6 of 10
Hi @goodmorninggood
You don't have such a number?
bye Fishtown
goodmorninggood
Message 7 of 10
Message 7 of 10
I have a repair label on it that says 'Artikelnr. 10021110', which looks the same format as the one you sent. Hope this one is right! Thanks for all your help already!
Message 8 of 10
Message 8 of 10
Hello @goodmorninggood ,
I can't find msn 10021110 in the database.
but there is one on the services page, unfortunately there are no technical details stored there.
found this on the internet 1002110B.
https://www.amazon.de/-/en/Medion-P5390-PC-System-Nvidia-GeForce/dp/B01FG336ZQ
is this the same as yours?
bye Fishtown
goodmorninggood
Message 9 of 10
Message 9 of 10
Yep - that looks like it!
Found this on the MSN lookup on medion.com - I assume it is the same page you found, not sure it tells me anything about CPU compatability? https://www.medion.com/gb/service/product-detail/10021110
In terms of taking a gamble on a CPU given the lack of details from Medion, would you say the I7 6700 or 6700k would be a good bet?
Thanks!
Message 10 of 10
Message 10 of 10
Processor Support
Socket LGA 1151
Chipset
Intel GL82H110
USB 3.0 Controller
Intel integrated
USB
Memory Support
Network
WLAN: ./.
IEEE1394: ./.
Audio
Serial ATA
BIOS
1 x SPI, SPI_DEBUG
Slots
1 x PCIe x16
2 x PCIe x1
bye Fishtown
9 REPLIES 9
