CPU upgrade AKOYA P5390
9 ANTWORTEN 9
goodmorninggood
Nachricht 1 von 10
10.028 Aufrufe
Nachricht 1 von 10
10.028 Aufrufe
Hello - I have an old ‘MEDION® AKOYA P5390 DR Multitasking Desk’, still runs pretty well, but wanted to look at upgrading the CPU.
I can’t find any information about the motherboard let alone a manual with compatible CPUs - the motherboard model number is
H110H4-CM2.
Does anyone have any advice?
Nachricht 10 von 10
9.952 Aufrufe
Nachricht 10 von 10
9.952 Aufrufe
Infos to ECS H110H4-CM2_DDR3L S1151 IPO W10 / MSN 20059419
Processor Support
Socket LGA 1151
Chipset
Intel GL82H110
USB 3.0 Controller
Intel integrated
USB
2 internal USB3.0 ports
2 USB 3.0 Back Panel Connectors
2 USB 2.0 Back Panel Connectors
Memory Support
DDR3L 1333 / 1600 MHz (16 GB Max)
2 DDR3L DIMMs (240pin / 1.35V only)
Single / Dual channel mode
Network
LAN: 10/100/1000 Fast Ethernet by Realtek RTL8111GN
WLAN: ./.
IEEE1394: ./.
Audio
6 channels audio codec Realtek ALC662-VD
1 x Front line out (green) / 1 x Line IN (blue) / 1 x Microphone in (pink)
Serial ATA
M.2(2260 and 2280 size with flexible standoff, only SATA mode supported)
Serial ATA: 3 x SATA III ports (black color)
BIOS
BIOS Manufacturer: AMI EFI BIOS APTIO core (new EFI)
BIOS Version: 110H4W0X.1xx (Medion specification)
BIOS Type: SPI flash (64Mbit)
Back panel: 2 x USB 2.0 / 2 x USB 3.0 / 1 x LAN (RJ45) / 1 x VGA output /  1 x HDMI output
On-Board Pinheaders:
1 x CPU 4PIN Fan header, CPU_FAN
1 x System Fan header, SYS_FAN
1 x Front Audio, F_AUDIO with purple plastic header
1 x Frontside USB :F_USB1 with Yellow plastic header
1 x Frontside USB :F_USB2 with black plastic header
1 x USB3.0 H10x2 front header F_USB30 (Intel pin out)
1 x Front_Panel header, F_PANEL black plastic header, 1 x 4PIN ATX 12V connector, ATX_12V
1 x 24PIN ATX connector "ATX_POWER"
1 x SPI, SPI_DEBUG
Slots
1 x PCIe x16
2 x PCIe x1
Abmessungen / Gewicht
Form Factor: Micro-ATX
Looks good according to the database:
the I7-6700K (CPU Intel Core i7-6700K 4,0 GHz)
it was installed in the board H110H4-CM2, see here:
bye Fishtown
9 ANTWORTEN 9
mats749
Nachricht 2 von 10
10.017 Aufrufe
Nachricht 2 von 10
10.017 Aufrufe
Hi @goodmorninggood
And welcome to the community!
Please can you provide me with the MSN number of the product so that I can check that for you.
Thanks
Mats749
goodmorninggood
Nachricht 3 von 10
10.005 Aufrufe
Nachricht 3 von 10
10.005 Aufrufe
Removed wrong info
Nachricht 4 von 10
9.998 Aufrufe
Nachricht 4 von 10
9.998 Aufrufe
Hello and welcome
Unfortunately, that's the serial number. the MSN number is usually attached under the device. tilt it and look there.
Bye Fishtown
goodmorninggood
Nachricht 5 von 10
9.988 Aufrufe
Nachricht 5 von 10
9.988 Aufrufe
Removed info
Nachricht 6 von 10
9.980 Aufrufe
Nachricht 6 von 10
9.980 Aufrufe
Hi @goodmorninggood
You don't have such a number?
bye Fishtown
goodmorninggood
Nachricht 7 von 10
9.974 Aufrufe
Nachricht 7 von 10
9.974 Aufrufe
I have a repair label on it that says 'Artikelnr. 10021110', which looks the same format as the one you sent. Hope this one is right! Thanks for all your help already!
Nachricht 8 von 10
9.964 Aufrufe
Nachricht 8 von 10
9.964 Aufrufe
Hello @goodmorninggood ,
I can't find msn 10021110 in the database.
but there is one on the services page, unfortunately there are no technical details stored there.
found this on the internet 1002110B.
https://www.amazon.de/-/en/Medion-P5390-PC-System-Nvidia-GeForce/dp/B01FG336ZQ
is this the same as yours?
bye Fishtown
goodmorninggood
Nachricht 9 von 10
9.957 Aufrufe
Nachricht 9 von 10
9.957 Aufrufe
Yep - that looks like it!
Found this on the MSN lookup on medion.com - I assume it is the same page you found, not sure it tells me anything about CPU compatability? https://www.medion.com/gb/service/product-detail/10021110
In terms of taking a gamble on a CPU given the lack of details from Medion, would you say the I7 6700 or 6700k would be a good bet?
Thanks!
Nachricht 10 von 10
9.953 Aufrufe
Nachricht 10 von 10
9.953 Aufrufe
Processor Support
Socket LGA 1151
Chipset
Intel GL82H110
USB 3.0 Controller
Intel integrated
USB
Memory Support
Network
WLAN: ./.
IEEE1394: ./.
Audio
Serial ATA
BIOS
1 x SPI, SPI_DEBUG
Slots
1 x PCIe x16
2 x PCIe x1
bye Fishtown
9 ANTWORTEN 9
