CPU upgrade AKOYA P5390
9 ANTWOORDEN 9
goodmorninggood
Bericht 1 van 10
9.549 Weergaven
Bericht 1 van 10
9.549 Weergaven
Hello - I have an old ‘MEDION® AKOYA P5390 DR Multitasking Desk’, still runs pretty well, but wanted to look at upgrading the CPU.
I can’t find any information about the motherboard let alone a manual with compatible CPUs - the motherboard model number is
H110H4-CM2.
Does anyone have any advice?
1 GEACCEPTEERDE OPLOSSING
Geaccepteerd Solutions
Bericht 10 van 10
9.473 Weergaven
Bericht 10 van 10
9.473 Weergaven
Infos to ECS H110H4-CM2_DDR3L S1151 IPO W10 / MSN 20059419
Processor Support
Socket LGA 1151
Chipset
Intel GL82H110
USB 3.0 Controller
Intel integrated
USB
2 internal USB3.0 ports
2 USB 3.0 Back Panel Connectors
2 USB 2.0 Back Panel Connectors
Memory Support
DDR3L 1333 / 1600 MHz (16 GB Max)
2 DDR3L DIMMs (240pin / 1.35V only)
Single / Dual channel mode
Network
LAN: 10/100/1000 Fast Ethernet by Realtek RTL8111GN
WLAN: ./.
IEEE1394: ./.
Audio
6 channels audio codec Realtek ALC662-VD
1 x Front line out (green) / 1 x Line IN (blue) / 1 x Microphone in (pink)
Serial ATA
M.2(2260 and 2280 size with flexible standoff, only SATA mode supported)
Serial ATA: 3 x SATA III ports (black color)
BIOS
BIOS Manufacturer: AMI EFI BIOS APTIO core (new EFI)
BIOS Version: 110H4W0X.1xx (Medion specification)
BIOS Type: SPI flash (64Mbit)
Back panel: 2 x USB 2.0 / 2 x USB 3.0 / 1 x LAN (RJ45) / 1 x VGA output /  1 x HDMI output
On-Board Pinheaders:
1 x CPU 4PIN Fan header, CPU_FAN
1 x System Fan header, SYS_FAN
1 x Front Audio, F_AUDIO with purple plastic header
1 x Frontside USB :F_USB1 with Yellow plastic header
1 x Frontside USB :F_USB2 with black plastic header
1 x USB3.0 H10x2 front header F_USB30 (Intel pin out)
1 x Front_Panel header, F_PANEL black plastic header, 1 x 4PIN ATX 12V connector, ATX_12V
1 x 24PIN ATX connector "ATX_POWER"
1 x SPI, SPI_DEBUG
Slots
1 x PCIe x16
2 x PCIe x1
Abmessungen / Gewicht
Form Factor: Micro-ATX
Looks good according to the database:
the I7-6700K (CPU Intel Core i7-6700K 4,0 GHz)
it was installed in the board H110H4-CM2, see here:
bye Fishtown
9 ANTWOORDEN 9
mats749
Bericht 2 van 10
9.538 Weergaven
Bericht 2 van 10
9.538 Weergaven
Hi @goodmorninggood
And welcome to the community!
Please can you provide me with the MSN number of the product so that I can check that for you.
Thanks
Mats749
goodmorninggood
Bericht 3 van 10
9.526 Weergaven
Bericht 3 van 10
9.526 Weergaven
Removed wrong info
Bericht 4 van 10
9.519 Weergaven
Bericht 4 van 10
9.519 Weergaven
Hello and welcome
Unfortunately, that's the serial number. the MSN number is usually attached under the device. tilt it and look there.
Bye Fishtown
goodmorninggood
Bericht 5 van 10
9.509 Weergaven
Bericht 5 van 10
9.509 Weergaven
Removed info
Bericht 6 van 10
9.501 Weergaven
Bericht 6 van 10
9.501 Weergaven
Hi @goodmorninggood
You don't have such a number?
bye Fishtown
goodmorninggood
Bericht 7 van 10
9.495 Weergaven
Bericht 7 van 10
9.495 Weergaven
I have a repair label on it that says 'Artikelnr. 10021110', which looks the same format as the one you sent. Hope this one is right! Thanks for all your help already!
Bericht 8 van 10
9.485 Weergaven
Bericht 8 van 10
9.485 Weergaven
Hello @goodmorninggood ,
I can't find msn 10021110 in the database.
but there is one on the services page, unfortunately there are no technical details stored there.
found this on the internet 1002110B.
https://www.amazon.de/-/en/Medion-P5390-PC-System-Nvidia-GeForce/dp/B01FG336ZQ
is this the same as yours?
bye Fishtown
goodmorninggood
Bericht 9 van 10
9.478 Weergaven
Bericht 9 van 10
9.478 Weergaven
Yep - that looks like it!
Found this on the MSN lookup on medion.com - I assume it is the same page you found, not sure it tells me anything about CPU compatability? https://www.medion.com/gb/service/product-detail/10021110
In terms of taking a gamble on a CPU given the lack of details from Medion, would you say the I7 6700 or 6700k would be a good bet?
Thanks!
Bericht 10 van 10
9.474 Weergaven
Bericht 10 van 10
9.474 Weergaven
Processor Support
Socket LGA 1151
Chipset
Intel GL82H110
USB 3.0 Controller
Intel integrated
USB
Memory Support
Network
WLAN: ./.
IEEE1394: ./.
Audio
Serial ATA
BIOS
1 x SPI, SPI_DEBUG
Slots
1 x PCIe x16
2 x PCIe x1
bye Fishtown
9 ANTWOORDEN 9
