B360H4-EM BIOS CANT FIND ANYWHERE
14 REPLIES 14
dudelelxd
Message 1 of 15
Message 1 of 15
Hello, please someone give me the files to an old version of the bios for the b360h4-em motherboard. I cannot find it anywhere and I really need an old version as the current one doesnt work for my computer. I dont know why medion doesnt post bios updates for it anywhere. Please please help.
1 ACCEPTED SOLUTION
mats749
Message 2 of 15
Message 2 of 15
Hi @dudelelxd
Please can you confirm the MSN number of your computer? Please can you also confirm the BIOS version installed?
Thanks
Mats749
14 REPLIES 14
mats749
Message 2 of 15
Message 2 of 15
Hi @dudelelxd
Thanks
Mats749
zuqaa
Message 3 of 15
Message 3 of 15
hello me too i can't find it anywhere
motherboard: MEDION B360H4-EM
Date of BIOS: 06/17/2019
Bios Version : 360H4W0X.115
jlr
Message 4 of 15
Message 4 of 15
Hello Folks,
I'm experiencing unexpected reboots (with a blackscreen, no BSOD) and I've testet almost everything to try to find the problem. My only hope right now is to update the bios.
This is the current version as well:
motherboard: MEDION B360H4-EM (x64)
Thanks in advance Admin! ❤️
EastClintwood
Message 5 of 15
Message 5 of 15
Hello @jlr,
Please let me know your MSN or MD number so we can help you and also check for alternative solutions.
Regards
EastClintwood
jlr
Message 6 of 15
Message 6 of 15
Of course!
MEDION ERAZER MD34647
(intel i5-9400F)
Thanks in advance!
EastClintwood
Message 7 of 15
Message 7 of 15
Hello @jlr,
Try limiting the frame rate to 60 in the graphics driver (e.g. vsync on). This will reduce the load on the graphics card and, to some extent, the CPU.
If it doesn't crash then, it could indicate that something is overheating, or the power supply isn't providing a stable voltage at the limit.
Or if there is a restore point from before the problem, you could reset to that to rule out a possibly faulty driver update.
If that doesn't help, I can send you version 116 via private message, which is the latest version. Feel free to contact me if the above suggestions were not a solution 🙂
Regards,
EastClintwood
jlr
Message 8 of 15
Message 8 of 15
Hi there,
Thank you for your response.
I've tried already some options regarding the Graphic Card with no luck. Would you be so kind to send me the Bios file and the instructions how to flash the Bios? THANKS!
Red
Visitor
Message 9 of 15
Message 9 of 15
Hallo Können Sie mir das aktualisierte BIOS schicken? Demir
MD34368/C884
Amerikan Megatrendleri Inc. 360H4WOX.115, 17.06.2019
SMBIOS 3.2
MEDION
B360H4-EM
V1.0
Tags (1)
kubakuba77
Message 10 of 15
Message 10 of 15
Hello, i have this one :
Motherboard: MEDION B360H4-EM
can You send version 116 bios update file ?
thanks in advance
regards
14 REPLIES 14
