Lifetec erazer LT9814
1 ANTWOORD 1
davyc10
Bericht 1 van 2
791 Weergaven
Bericht 1 van 2
791 Weergaven
Dear
I have the Lifetec Erazer joystick and would like to be able to add it to my computer to play Farming Simulator. My computer is running Windows 11. I connected the controller to my computer using an intermediate cable, namely from gameport to USB.
Do you have a driver or software that allows my computer to recognize the controller?
1 ANTWOORD 1
Bericht 2 van 2
787 Weergaven
Bericht 2 van 2
787 Weergaven
hello @davyc10 and welcome
This won't work even if you find drivers for the 24 year old joystick.
because the stick doesn't have a USB interface and therefore the USB interface fails because you only have one cable with two different game port-USB connectors.
The signals from the stick are therefore not understood.
bye Fishtown
1 ANTWOORD 1
