strange sound at the begining of Windows
3 ANTWORTEN 3
and76
Nachricht 1 von 4
2.051 Aufrufe
Nachricht 1 von 4
2.051 Aufrufe
Hi guys.
I have problems with my laptop, a Medion Erazer Deputy P10 (MD63665). The system, a few minutes after starting Windows, emits a beep or two through the speakers, they are unique and do not repeat them. I have checked everything with software and it reports no problems. I've reset Setup settings to factory mode, uninstalled audio driver updates, but it keeps beeping. Any advice?
Regards.
3 ANTWORTEN 3
Burki48
Nachricht 2 von 4
2.043 Aufrufe
Nachricht 2 von 4
2.043 Aufrufe
Hello @and76 ,
When exactly did the problem start? Was a Windows update carried out shortly before? Can music or sounds still be played properly? How exactly did you restore the factory settings?
Greetings
Burki
and76
Nachricht 3 von 4
1.997 Aufrufe
Nachricht 3 von 4
1.997 Aufrufe
Dear Burki.
Sorry for the delayed answer. The "sounds" were sticky keys activated...
Thank you for your support.
Burki48
Nachricht 4 von 4
1.990 Aufrufe
Nachricht 4 von 4
1.990 Aufrufe
Hello @and76 ,
thank you for your feedback. So now everything is OK again with the sounds?
Greetings
Burki
3 ANTWORTEN 3
