on 25.08.2023 11:09
on 25.08.2023 11:09
I purchased this radio from my local ALDI store yesterday 24/08/2023.
Reason for purchase was to have a AM/FM radio with ability to preset stations.
The preset station function appears to be working fine so far.
However the Storing Favourites function (page 20 of User Manual) is not working.
After I select a station to be stored as a favourite, I then hold down on of the 4 buttons.
The button I hold down then disappears from the screen display but when I then press that button the station has not been stored.
For example when I tried 1st time, all 4 buttons 1 2 3 4 were displayed on screen.
I then selected a station and held down button 1, until that button disappeared from the screen. When I then pressed button 1 the station I expected did not come on.
Are there some restrictions on using this Storing Favourites feature?
I have followed the instructions on page 20 without success.
on 25.08.2023 18:08
on 25.08.2023 18:08
Hello @KeenShopper99 and welcome
I wouldn't understand the instructions any differently than you already have.
Do you have to hold down the button longer?
Hold until the button is confirmed and reappears?
Bye Fishtown
on 28.08.2023 08:39
on 28.08.2023 08:39
Hi Fishtown
Thanks for your reply - however holding down the button longer does not make any difference.
I've tried a few options and have discovered the following solutions.
Solution 1
Select the station required to be set as a favourite.
Press and hold the favourite button required until that numbered button disappears from the screen display.
Press that same favourite button again.
The same button will re-appear on the screen display and the station required will be set as a favourite for that button.
Solution 2
(This is basically same as solution 1, except steps above done in a different order.
First press & hold the favourite button required until that numbered button disappears from the screen display.
Extra Note
It seems that my new radio came with station numbers preset in the 4 favourite buttons, explaining why I initially saw the 4 buttons displayed on the screen as 1 2 3 4.
So it seems the process of holding the favourite button until it disappears from the display screen effectively clears the stored station from that button.
Hope this all helps any other radio users.
Final Note/Issue
When I set the time, it does not stay stored when radio is switched off from mains power, so need to reset this every time.
Have not tried yet with batteries - maybe time will be stored if batteries in use??
Subject | Author | Posted | |
15.02.2021 02:47 | |||
23.09.2024 15:40 | |||
08.05.2024 23:04 | |||
11.12.2020 19:27 |
