Install APK or other application on MEDION LIFE X15850
3 REPLIES 3
Insinfi
Message 1 of 4
Message 1 of 4
Hello,
Is there a way to install an APK or any other application on  MEDION LIFE X15850. I have seen that there is a store but there isn't any of the application that I'm looking for.
Or do I need to put and Android Box / Fire stick / ... to be able to add some other apps ?
Thanks
2 ACCEPTED SOLUTIONS
P1a5ma-
Message 2 of 4
Message 2 of 4
Hi Insinfi,
You'll need to use an external android  box to access additional apps as the only ones supported come preinstalled.
Thanks.
Insinfi
Message 4 of 4
Message 4 of 4
So I have opted for a new generation Chromecast that work perfectly it can even replace the remote. Thanks for your help!
3 REPLIES 3
P1a5ma-
Message 2 of 4
Message 2 of 4
Hi Insinfi,
Thanks.
Insinfi
Message 3 of 4
Message 3 of 4
Yeah that is the option I will use, thanks for your help
Insinfi
Message 4 of 4
Message 4 of 4
3 REPLIES 3
