Install APK or other application on MEDION LIFE X15850
4 ANTWOORDEN 4
Insinfi
Bericht 1 van 5
3.605 Weergaven
Bericht 1 van 5
3.605 Weergaven
Hello,
Is there a way to install an APK or any other application on  MEDION LIFE X15850. I have seen that there is a store but there isn't any of the application that I'm looking for.
Or do I need to put and Android Box / Fire stick / ... to be able to add some other apps ?
Thanks
2 GEACCEPTEERDE OPLOSSINGEN
Geaccepteerd Solutions
P1a5ma-
Bericht 2 van 5
3.586 Weergaven
Bericht 2 van 5
3.586 Weergaven
Hi Insinfi,
You'll need to use an external android  box to access additional apps as the only ones supported come preinstalled.
Thanks.
Insinfi
Bericht 5 van 5
3.246 Weergaven
Bericht 5 van 5
3.246 Weergaven
So I have opted for a new generation Chromecast that work perfectly it can even replace the remote. Thanks for your help!
4 ANTWOORDEN 4
P1a5ma-
Bericht 2 van 5
3.587 Weergaven
Bericht 2 van 5
3.587 Weergaven
Hi Insinfi,
Thanks.
Insinfi
Bericht 3 van 5
3.539 Weergaven
Bericht 3 van 5
3.539 Weergaven
Yeah that is the option I will use, thanks for your help
NoelAdoo
Visitor
Bericht 4 van 5
3.258 Weergaven
Bericht 4 van 5
3.258 Weergaven
Done. 🙂 Thanks
.I want to know how to install APK or other application on MEDION LIFE X15850. I am glad I found your post. I also found https://writinguniverse.com/free-essay-examples/food/ website where I can read essay samples for free.
Insinfi
Bericht 5 van 5
3.247 Weergaven
Bericht 5 van 5
3.247 Weergaven
4 ANTWOORDEN 4
