Fan Speed Setting No correct temp
1 REPLY 1
ErikDK64
Message 1 of 2
Message 1 of 2
I have had an issue with the fan speed setting app within Control Center since I first got my laptop.
I always thought it was weird how the APU ran at 70°C idle but did not think much of it until I checked my Task Manager, which displayed lower temps for my APU.
I have tried reapplying thermal paste, which helped a little bit. It, however, did not change anything for the difference in temps.
My laptop: MEDION ERAZER Deputy P25 MD62343
Software I am using: Fan Speed Setting version 3.47.0.0 (came with the laptop, only did an update recently)
This is a screenshot of the GPU temp being accurate, but the second "GPU" temp (this is the APU) being significantly higher.
If anyone has any ideas, please let me know.
1 REPLY 1
Mastermind
Message 2 of 2
Message 2 of 2
Hi @ErikDK64 ,
I´m wondering which Bios version you are currently running an can provide you V 1.07.05RME1, which can be downloaded here.
Please remind, that for any errors, caused by the execution of this update, we don´ t accept any responsibility for damage or lost of data.
Cheers
1 REPLY 1
