Control Centre for MEDION Erazer Recon E45 Gaming PC
9 REPLIES 9
baymax
Message 1 of 10
Message 1 of 10
Hi,
I recently bought a MEDION Erazer Recon E45 Gaming PC and is my first proper gaming PC so I don't quite understand how to find the control centre. I'm looking to change the RGB as the site where I purchased this said the RGB was customisable. I've tried countless softwares for RGB and cannot find any that recognise my devices and the site itself said the ERAZER control centre was the place to go but I cannot find a download link and I cannot find it in any drivers.
Thank you in advance 🙂
1 ACCEPTED SOLUTION
Message 8 of 10
Message 8 of 10
Hi @baymax
I found something else, it can probably be switched manually
https://cdn.medion.com/downloads/anleitungen/flyer_20072371.pdf
Didn't the computer come with an additional flyer where this is described?
bye Fishtown
9 REPLIES 9
Message 2 of 10
Message 2 of 10
hello @baymax  and welcome
In order to be able to say something more, you must provide the MSN number from the computer.
And a link to the product page wouldn't be bad either.
bye Fishtown
baymax
Message 3 of 10
Message 3 of 10
Thank you for the quick reply!
MSN number: 10025693
Let me know if you'd like me to find the link as well
Message 4 of 10
Message 4 of 10
Hi @baymax
yes, I think you should provide the link. As I see it, you can't control the fan LED. no ARGB slot on the board.
bye Fishtown
baymax
Message 5 of 10
Message 5 of 10
Message 6 of 10
Message 6 of 10
Hi @baymax
the link doesn't work
bye Fishtown
baymax
Message 7 of 10
Message 7 of 10
This was the attached image that suggested the fans would change colour
Are there any specifications you would want me to copy and paste from the site since the link is faulty on your end?
Message 8 of 10
Message 8 of 10
Hi @baymax
bye Fishtown
baymax
Message 9 of 10
Message 9 of 10
I tried looking for it but I wasn't sure what a lot of it meant - I'm very new to this and this is the first PC I've bought. I will investigate it further though and get back to you, thank you for your help!! 🙂
baymax
Message 10 of 10
Message 10 of 10
THANK YOU SO MUCH, I completely missed that box and this was the correct solution. It has successfully changed, THANK YOU!
9 REPLIES 9
