Old Medion MD 41260 scanner driver and software for Windows xp
1 REPLY 1
Ovanes
Message 1 of 2
Message 1 of 2
I have a Medion MD 41260 scanner which I used a long time ago. Now I want to scan my old Kodak film slides. Unfortunately I don't have the appropriate software for the scanner. It works under Windows XP only. Would you help me in my efforts?
Tags (1)
1 ACCEPTED SOLUTION
Message 2 of 2
Message 2 of 2
Hi @Ovanes and welcome
look here:
https://www.driverguide.com/driver/detail.php?driverid=1873715
Important:
Just click here and download the scannerCD.zip file
You'll then have to confirm that you're not a robot and click on a selection of images. The download of the Scanner-CD.zip file will begin.
Caution: A Slim-U2-TA_Fre-outbyte-driver-updater.exe will also be downloaded automatically. I don't know what it's for.
You just have to unzip the Scanner-CD.zip file and run the setup file.
bye Fishtown
You can find the driver and manual here: https://www.medion.com/gb/service/product-detail/50012283
1 REPLY 1
Message 2 of 2
Message 2 of 2
look here:
Important:
bye Fishtown
1 REPLY 1
