All drivers
1 ANTWOORD 1
Alexis93
Bericht 1 van 2
13.892 Weergaven
Bericht 1 van 2
13.892 Weergaven
All drivers
Hello
I have an Medion Akoya E2228T  MD61050 MSN 30023301.
I download from here  : https://www.medion.com/gb/service/start/_product.php?msn=30023301&gid=00  all drivers for my notebook but i canno't install all of them .
I try to install all of drivers , but many folders ar without .exe or install app.
Can you help me ?
Thank You !
1 ANTWOORD 1
Bericht 2 van 2
13.888 Weergaven
Bericht 2 van 2
13.888 Weergaven
@Alexis93
Doubleclick the downloaded file. It will extract  into a folder C:\ Medion.
First make use of the platform-Installer  ->  C:\Medion\01_Chipset\Installer\PlatformInstaller\x64\Drv64.exe
Afterwards, for Wlan,  Bluetooth and Audio-Output you have to install again in the device-manager by clicking driver-update, and pointing the path to the appropriate folder. The installation will find the suitable inf-files in the corresponding subfolders to install the drivers.
regards, daddle
1 ANTWOORD 1
