ANDROID RECOVERY PAKET
7 RÉPONSES 7
ZAJDAN
Message 1 sur 8
5 930 Visites
Message 1 sur 8
5 930 Visites
Hello,
I have downloaded  ANDROID RECOVERY PAKET for my
  • MEDION LIFETAB P7332 Serie
now I am trying run the flash.sh from linux-desktop, but the script returns a few errors:
zajdan@linux-desktop1:/usr/bin$ sh /home/zajdan/Downloads/medion-p7332/flash.sh
/home/zajdan/Downloads/medion-p7332/flash.sh: 22: [: unexpected operator
/home/zajdan/Downloads/medion-p7332/flash.sh: 27: [: unexpected operator
*** Intel flash process stage 1 ***
1) Power off the device.
2) Press and hold [Power]+[VolUp]+[VolDn] for 5 seconds.
3) Connect device to PC via USB.
error: cannot load '/efilinux-.efi': No such file or directory
cannot load '/droidboot.img': No such file or directory
Sleeping for 10 seconds...
*** Intel flash process stage 2 ***
/home/zajdan/Downloads/medion-p7332/flash.sh: 57: [: true: unexpected operator
error: cannot load '/esp.img': No such file or directory
error: cannot load '/droidboot.img': No such file or directory
erasing 'system'...
FAILED (remote: unknown command)
finished. total time: 0.005s
error: cannot load '/esp.zip': No such file or directory
error: cannot load '/boot.img': No such file or directory
error: cannot load '/recovery.img': No such file or directory
error: cannot load '/system.img': No such file or directory
/home/zajdan/Downloads/medion-p7332/flash.sh: 82: [: true: unexpected operator
resuming boot...
finished. total time: 0.000s
*** Finished.                   ***
Thanks for any hint
7 RÉPONSES 7
Message 2 sur 8
5 891 Visites
Message 2 sur 8
5 891 Visites
@ZAJDAN
Hi zajdan, a couple of thoughts; maybe some help, or I miss the clue in total. I am no linux.man. Smiley triste
1. Why don't you change in terminal to your download-folder first, then into the unpacked "medion-p3320" folder, and issue the flash.sh command there? (or,  check point 4)
2. Did you create or edited the udev/rules, like mentioned in the install guide point 2.?
3. Did you unzip the recovery-package in linux?
4. Maybe You have to make use of command  -> ./flash.sh  or sudo ./flash.sh; (or just sudo flash.sh)
Success, daddle
ZAJDAN
Message 3 sur 8
5 862 Visites
Message 3 sur 8
5 862 Visites
it was the first what I did...run the script from the folder where it is placed
root@linux-desktop1:/home/zajdan/Downloads/medion-p7332# ./flash.sh
error: cannot load '/efilinux-user.efi': No such file or directory
ZAJDAN
Message 4 sur 8
5 860 Visites
Message 4 sur 8
5 860 Visites
I edited the script and instead of variable $OUT I have put there absoluth path, where I have the files and now it is ok.
but appears another problem....when the script starts process stage 2
on tablet is 'warning'
EFILINUX ERROR [efi_main:529] fs_init failed, DnX mode?
is it problem?
Message 5 sur 8
5 841 Visites
Message 5 sur 8
5 841 Visites
@ZAJDAN
Your first post above said this; which is not starting from inside the folder medion-p7332. Thats why the flash.sh couldn't find any files. But you still persist:
ZAJDAN wrote:
"it was the first what I did...run the script from the folder where it is placed"
Quite a difference to the way you stated you starting the flash.sh in your post 1.
And it doesn't work anyway; So I am Sorry, can't follow your argumentation.
Good luck, daddle
ZAJDAN
Message 6 sur 8
5 828 Visites
Message 6 sur 8
5 828 Visites
as I wrote...when I changed in the script instead of variable $OUT my absolute path...script loads the files without problem
if You do not believe me, that when I run the script(default version) from the folders where are the files, so I can demonstrate it in more details.
Message 7 sur 8
5 824 Visites
Message 7 sur 8
5 824 Visites
@ZAJDAN
No, I do  believe you, there was just one contradiction in your postings which puzzled me.
ZAJDAN
Message 8 sur 8
5 822 Visites
Message 8 sur 8
5 822 Visites
I am glad, that someone communicate with me and try to help, Thanks for Your time.
Anyway I am facing another problem about the EFI BOOT FIX:
https://community.medion.com/t5/Tablet/EFI-Boot-Fix-doesn-t-help/m-p/42053#U42053
7 RÉPONSES 7
