Medion erazer x7847. How to turn off the LED keyboard or change the color?
14 REPLIES 14
dycpepsi
Message 1 of 15
Message 1 of 15
Hello friends, I bought this notebook without an operating system. I installed windows 10. The keyboard is always illuminated in blue. The key combination FN + / * - + should control the lighting of the keyboard but it does not work.
I believe that the correct drivers are not available on the medion website. The device manager recognizes it as PS / 2 Standard Keyboard.
Do you know how I can turn off the keyboard illumination and how to change the color?
Thank you.
1 ACCEPTED SOLUTION
dycpepsi
Message 4 of 15
Message 4 of 15
Hello, I have already solved it. I have downloaded the control center program and everything is working perfectly.
Thanks for everything.
A greeting.
Control Center -
14 REPLIES 14
Bodgekin
Message 2 of 15
Message 2 of 15
Hi @dycpepsi
What is the MSN number of your notebook? I don't think the keyboard drivers are the problem, I think you need either an extra Hotkey driver / software, or some form of controll software.
Kind regards,
Bart
dycpepsi
Message 3 of 15
Message 3 of 15
Hello, thanks for replying. The Msn is:  30022356
I bought the notebook without an operating system. I do not have any software.
I downloaded all the drivers from the official medion website but I can not find anything for the keyboard.
I have all the drivers working correctly except the keyboard. It does not recognize  some combinations of keys FN + key among them those of the keyboard illumination.
Do you know any extra Hotkey driver / software, or some form of controll software for this notebook?
Thanks.
dycpepsi
Message 4 of 15
Message 4 of 15
A greeting.
Control Center -
Bodgekin
Message 5 of 15
Message 5 of 15
Hi @dycpepsi
Great to see you already solved it, and thanks for posting the solution, might help others as well!
Kind regards,
Bart
rebandrob
Message 6 of 15
Message 6 of 15
I have the same problem with my X7859 MSN:30025453 .... can you tell me how to repair it?. Thanks.
Roberto
Message 7 of 15
Message 7 of 15
Hi @rebandrob
Install the Control Center Software: http://www1.medion.de/downloads/download.pl?lang=de&filename=ctrx785x_6x_w10.exe&id=18409&type=treib...
Bye Fishtown
madmax99
Message 8 of 15
Message 8 of 15
Hi i have the same issue please helppp asap
Message 9 of 15
Message 9 of 15
Hello @madmax99 and welcome,
the solution is there! or what is your problem!
Which version do you have, X7959 or X7847.
Please enter your MSN number.
bye Fishtown
madmax99
Message 10 of 15
Message 10 of 15
my msn is 3002 9419
14 REPLIES 14
