Driver
8 REPLIES 8
dolph
Message 1 of 9
Message 1 of 9
Driver
I have just purchased a Medion Life Smartphone E5005.  I cannot find a driver for it.  Can anyone please point me in the right direction.
8 REPLIES 8
McB
Message 2 of 9
Message 2 of 9
moin @dolph - welcome!
which driver do you intend and what for¿
do you intend something like 'MyPhoneExplorer'¿
otherwise please specify...
good luck & greetings
dolph
Message 3 of 9
Message 3 of 9
Yes I want to connect to my laptop to explore it but cannot find correct driver
McB
Message 4 of 9
Message 4 of 9
did you try:
MyPhoneExplorer
obviously for your laptop and the client via play.google¿
both should do it...
dolph
Message 5 of 9
Message 5 of 9
Thank you for your reply but I cannot see my phone when I connect it to the laptop.  There seems to be a problem with the usb driver required by the device.
Bodgekin
Message 6 of 9
Message 6 of 9
Hi @dolph
Normally when you connect a smartphone you get a small USB icon on the top of the screen, by tapping on that you should be able to choose the USB mode, either charging mode or mass storage mode. When the phone is set to charging mode, Windows will not recognize the device and it will just charge over USB. When it is set to mass storage mode, Windows should be able to install the device using generic mass storage drivers (the same drivers that are also used for usbsticks, memorycards, etc. )
Kind regards,
Bart
tw2016
Message 7 of 9
Message 7 of 9
I had the same problem, and it drove me crazy.
After maaany hours I finally noticed that I connected my Medion with a power-only USB cable (which came with other hardware and was meant just for charging), and not a real USB cable.
When I used a real / normal USB cable, it finally worked.
I noticed that I didn't use a real USB by the fact that the usual pop-up wouldn't appear on my Medion when I plugged the USB cable.
CynthiaHoward
Sleeper
Message 8 of 9
Message 8 of 9
@Bodgekin wrote:
Hi @dolph
Normally when you connect a smartphone you get a small USB icon on the top of the screen, by tapping on that you should be able to choose the USB mode, either charging mode or mass storage mode. When the phone is set to charging mode, Windows will not recognize the device and it will just charge over USB. When it is set to mass storage mode, Windows should be able to install the device using generic mass storage drivers (the same drivers that are also used for usbsticks, memorycards, etc. ) www.tellpopeyes.com
That's great. I was impressed by your writing. I am happy to see such a topic. Please come to my blog and read it.
jhonmu
Message 9 of 9
Message 9 of 9
Impressive
8 REPLIES 8
