20.08.2017 10:38
20.08.2017 10:38
Hello,
During an SSD disk upgrade from 64Gb to 256Gb (Win10 Creators updates are eating the disk space so fast), I've got a blue screen upon restarting the machine.(error 0xc000000e)
I was invited (Escape) to return to the UEFI / BIOS to change boot parameters which I did.
So far so good, the machine started again in Windows 10.
However since that event, I can no longer get into the BIOS with F2.
I get only a black screen with a fixed dash on the upper left corner.
So I can no longer change any bios parameter and F12 (boot device selection) does no longer work.
This is an extremely dangerous situation for a machien professionnally used.
On an MSI forum related to the same machine (X7611=GS70 barebone) an MSI tech advised to re-flash the BIOS which solved the problem.
I've scoured the web to find the Medion X7611 bios file (E1771IM7.5xx) to no avail. (board MS-1771 rev 1.1)
I've made a backup of my BIOS (E1771IM7.500 23-02-2013) after the problem, and the file size is only 3072Kb i.o the 8192Kb of the GS70 BIOS.
The other clone Schenker XMG C703 Bios file is also of the smae size, 8192Kb.
So something is missing.
Does anyone have already flashed a GS70 2P STEALTH Bios in the Medion X7611?
Could anynone make a backup of the X7611 bios in his healthy machine ? (with AFUWINx64.EXE you can make a backup)
Any help would be appreciated.
Thanks
Yves
