Wer hatte die gleiche Frage?
Noel
16.406 Aufrufe
16.406 Aufrufe
Horrible fan noise from new MEDION ERAZER ENGINEER P10 MD35007 (with 3060ti)
Hello,
I've recently purchased a gaming desktop from Medion (ERAZER ENGINEER P10 MD35007). There is some unbearable loud and noise (although it sounds functional) coming from the back of it when the GPU is under load. I can't determine for sure if it comes from the Power Supply or from the Fan(with blue led) just underneath it. So far I'd say 60% chance from the power supply.
I reduced the fans(with blue leds) rotation to 600-700 rpm wih the help of Bios modifications and a software but it doesn't fix the issue at all.
i really don't want to send the tower back since I like the components and design and I don't want to wait 3 weeks for a refund (just sent back another desktop last month because the GPU didn't matched the description).
So what are my options and what could Medion do to help ?
Should I change the fans and if it doesn't solve the issue, change the power supply ?
What do you think ?
