am 04.04.2021 18:58
am 04.04.2021 18:58
Hello,
I bought the pc, the pc was keep beeping in every 10 seconds( sometimes shorter sometimes longer ), but works just fine totally.
after using about 3 months, I moved away for quiet long time and just brought back this pc and started using it again, but it's still making the beeping sound but again it works perfectly fine.
I tried to open it to clean a bit before using it.
but it seemed impossible to open ( it has only 8 cross screws and theres a lot of screws that cant rotate with screw driver. i have no idea how to remove it. it just has round hole in the middle.
but anyways the pc was quiet well covered and only has few opened space only around the fan, and when I looked inside it was just clean so I decided to just use it and it works perfectly.
its overall working perfectly but I cannot stop worrying about something might be wrong with the pc.
thanks
jackyjoy
