46148members
656online
158119posts
The diskpart command interpreter helps you to manage your computer's drives (disks, partitions, volumes, or virtual hard disks).
Before you can use diskpart commands, you must first list, and then select an object to give it focus.
After an object has focus, any diskpart commands that you type will act on that object.
