46056members
9213online
158085posts
Slimline drives are preferably installed in notebooks, DVD players and game consoles. They have a reduced size (usually 12.7 mm height,128 mm width and 129 mm depth), which also makes them need a special form of SATA connector.
This was first defined under SATA 2.6 and consists of a signal segment and a power supply segment. The slimline connector has only a 6-pin power supply, which can only supply 5V devices.
| Segment | Pin | Designation | Function |
| Signal segment | S1 | GND | Ground |
| S2 | A+ | Differential signal | |
| S3 | A- | Differential signal | |
| S4 | GND | Ground | |
| S5 | B+ | Differential signal | |
| S6 | B- | Differential signal | |
| S7 | GND | Ground | |
| Power supply segment | P1 | DP | Device presence |
| P2 | +5V | Supply voltage | |
| P3 | +5V | Supply voltage | |
| P4 | MD | Manufacturer diagnosis | |
| P5 | GND | Ground | |
| P6 | GND | Ground |
Article in other languages:
