TV MD31555 nach update Zwei Bilder nebeneinander
32 RÉPONSES 32
Armade75
Message 1 sur 33
6 669 Visites
Message 1 sur 33
6 669 Visites
bin morgen aufgewacht und gemerkt das meine TV MD31555 MSN: 30035208 ein update gemacht.
Was nicht schlimm ist, aber seid dem habe ich zwei Bilder nebeneinander und geht nicht weg.
hab Reststrom und neu Installation alles hast nichts gebracht.
Service PHOTO-2024-06-08-17-19-57.jpg bringt keine Hilfe
danke für ihre Hilfe
32 RÉPONSES 32
Marcus080271
Message 21 sur 33
1 814 Visites
Message 21 sur 33
1 814 Visites
hi,
same here. i used the chat function. a technican will visit me at home to check the problem directly.
the update with a usb stick didnt worked at my tv too. i saw the saved modus but the firmware didnt start from usb
greetings marcus
Armade75
Message 22 sur 33
1 772 Visites
Message 22 sur 33
1 772 Visites
I got a new email from support, how far have you come?
Verthosa
Message 23 sur 33
1 745 Visites
Message 23 sur 33
1 745 Visites
Also in contact with support, they will send someone over i think
Marcus080271
Message 24 sur 33
1 741 Visites
Message 24 sur 33
1 741 Visites
i got this morning a email from support too. they want pics from the tv, there is shown the software version installed at the tv. a picture from the failure ( i ve sent one with the 2 homescreens)
my tv is about 1 year old. im sure the problem is only a software prob. its a prob from android, not medion.
now looking for that they will do to solve it.
greetings marcus
Verthosa
Message 25 sur 33
1 737 Visites
Message 25 sur 33
1 737 Visites
Same, i just sent all the pictures, customer NO, serial NO etc...
Why do you think it is an Android software problem? It sure is a software/firmware problem, but it is Medion that prepares and publishes the firmware updates in my opinion?
The split screen also occurs on the cable/AV/satellite mode of the TV. This is not Android...
Marcus080271
Message 26 sur 33
1 730 Visites
Message 26 sur 33
1 730 Visites
i thought so, cause the main system is android. probably u have right and medion used a not correct software version .
split screen is a normal function i know from my samsung tv s. and now we cant change back to the single screen mode. i think they have to create a new software function to solve the prob
what i me ask is, how long we have to wait until its ok
Armade75
Message 27 sur 33
3 544 Visites
Message 27 sur 33
3 544 Visites
Jungs jetzt habe ich das erledigt
http://cdn.medion.com/downloads/software/Firmware_Full_Update_MD31555.zip
2. Dateinamen der Firmware kontrollieren. Das MDS am Anfang ist zwingend erforderlich. Gegebenenfalls umbenennen
- Dateiname MDS_upgrade_image_no_tvcertificate.pkg = korrekt
- Dateiname upgrade_image_no_tvcertificate.pkg = nicht korrekt
3. Gerät von der Spannungsversorgung trennen
4. USB-Stick anstecken
5. Spannungsversorgung herstellen
6. Updatevorgang beginnt.
7. Gerät startet nach Beendigung automatisch neu, der USB-Stick muss entfernt werden
8. Der Erststart nach dem Update nimmt einige Zeit in Anspruch. Bitte den Start bis zur Erstanmeldung abwarten.
bitte sag bescheid ob das bei euch funktionieret bei mir ja
nicht die Anleitung im zip Datei benutzen einfach usb obere nehmen wieder in an strom und dann gehts automatisch
Verthosa
Message 28 sur 33
1 720 Visites
Message 28 sur 33
1 720 Visites
Ow, that is great, what do you mean by MDS? Just the letters MDS or some kind of code?
Will try this tonight when i get home and will let you know
Armade75
Message 29 sur 33
1 718 Visites
Message 29 sur 33
1 718 Visites
ja der Techniker meinte das war von der Techniker Fehler die Bezeichnung war Falsch.
( MDS_ ) Fehlt bei der andere Datei und nicht die Anleitung befolgen aus der zip Datei !!!
Armade75
Message 30 sur 33
1 707 Visites
Message 30 sur 33
1 707 Visites
or just download the file again
32 RÉPONSES 32
