MEDION Life X5020 Android Update
1 REPLY 1
Anonymous
None
Message 1 of 2
Message 1 of 2
I am trying to update the software of my MEDION Life X5020. I looked through all of the settings one by one, but I couldn't find where to update it. Could you please tell me where to update it and if it is eligible for Android 6? Best regards.
SERVERKARATEPE
1 ACCEPTED SOLUTION
EastClintwood
Message 2 of 2
Message 2 of 2
Hello @Anonymous, and welcome to the community.
If a software update is available for your smartphone, you can find it under:
Settings -> System & Updates -> Software Update.
Greetings,
EastClintwood
1 REPLY 1
EastClintwood
Message 2 of 2
Message 2 of 2
Greetings,
EastClintwood
1 REPLY 1
