Tevion/Médiím 4800dpi scanner
4 REPLIES 4
PaulDevall
Message 1 of 5
Message 1 of 5
I have had this scanner for some years and it worked perfectly in my XP and Win7 laptops but since getting an upgrade to Win10 it has been in the cupboard.
Is there any Win10 compatible software/drivers available for it?
It seems a shame to junk it.
4 REPLIES 4
PaulDevall
Message 2 of 5
Message 2 of 5
MEDION!!!
Predictive text eh!!!
PaulDevall
Message 3 of 5
Message 3 of 5
Model number is MD90090
Baba
Message 4 of 5
Message 4 of 5
Perhaps you could try manually installing the scanner driver for Windows 7 on Windows 10?  Sometimes it works.  At least this worked for me on my recent installation of an older 54Mbps Wi-Fi card. Windows 10 couldn't find the driver automatically, so I installed the older driver manually. I believe that it was even a Windows Vista driver.  Just a layman's thought, and if you try this, please do it at your own risk!
Stephan_de_Rako
Message 5 of 5
Message 5 of 5
Yes, it works also with Windows 10!
Look for Scanner Wizzard, and for einen TWAIN driver. (Mikrotek)
Stephan
4 REPLIES 4
