Sound Driver Issue X30 Beast - Mic Socket not working
1 ANTWORT 1
YompeRxx
Visitor
Nachricht 1 von 2
1.756 Aufrufe
Nachricht 1 von 2
1.756 Aufrufe
Hello, I have an Erazer X30 Beast.
When using a headset with the Realtek drivers, the headset mic does not work
On checking Device Manager in Windows 11, only one set of speakers and a mic is visible
If I install Microsoft's own audio driver, two sets of speakers and two mics can be seen
With this driver the mic socket also works
Is there a Realtek driver which will work properly with this laptop?
1 ANTWORT 1
EastClintwood
Nachricht 2 von 2
1.743 Aufrufe
Nachricht 2 von 2
1.743 Aufrufe
Hello @YompeRxx, and welcome to the community.
Here are two options to update the drivers manually:
Update device drivers
1. in the search box on the taskbar, type Device Manager, and then select Device Manager.
2. Select a category to display device names, then right-click (or press and hold) the device you want to update.
3. Select Automatically check for the latest driver software.
4. Select Update Driver.
5. If no new driver is found in Windows, you can search for a driver on the device manufacturer's website and follow the installation instructions.
Reinstalling the device driver:
In the search box on the taskbar, type Device Manager, and then select Device Manager.
Right-click (or press and hold) the name of the device, then select Uninstall.
Restart the PC.
Windows will try to reinstall the driver.
Please enter the MSN of your laptop at the following link :
MEDION Service
The appropriate drivers should be available there.
If problems persist, please let us know.
Regards,
EastClintwood
1 ANTWORT 1
