Invalid Windows Key after Reinstall
3 RÉPONSES 3
dhurley
Message 1 sur 4
3 559 Visites
Message 1 sur 4
3 559 Visites
I recently purchased a Medion ERAZER X87104 (MD34945) and am having some issues. When I first installed and went into windows I accidently signed in with my work account so wanted to reset windows back to factory settings.
When I done that the installation got stuck at 66% for over an hour so I stupidly turned off the PC to see if that would fix it..... It didnt.
From there I had a corrupt installation of windows and the Windows RE couldnt fix it.
I needed to use diskpart to clear the ssd drive and reinstall windows on it fresh (Using the windows media tool). All is working fine however now the Windows key that is on the back of the case does not work.
Not sure where to go from here or how to fix it. The sticker on my case says windows home oem software,  I installed Windows Home N. Could this be the issue?
3 RÉPONSES 3
Datwozza
Message 2 sur 4
3 556 Visites
Message 2 sur 4
3 556 Visites
Did it ask for a windows activation while installing windows?
dhurley
Message 3 sur 4
3 552 Visites
Message 3 sur 4
3 552 Visites
It did, but I said skip for now.
Datwozza
Message 4 sur 4
3 540 Visites
Message 4 sur 4
3 540 Visites
Oh, usually if it dont ask for a key then its activated.
If u cant activate it in windows then its probaly invalid. It dont really matter what version of windows you have.
If u have a pro key but have the home version the key will install the pro version when the key is entered.
3 RÉPONSES 3
