medion erazer crawler e30 problem with turning on
3 REPLIES 3
Wojtekw
Message 1 of 4
Message 1 of 4
I bought several Medion E30s and each one has trouble turning them on. sometimes it works normally, sometimes it's hard to turn it on with the battery and the power supply, I have a 19.5v 9.23a power supply. BIOS updated, RAM and disks changed and nothing. anyone have any ideas.
3 REPLIES 3
Batxokns
Message 2 of 4
Message 2 of 4
I have an e30 that I bought two weeks ago, no matter what update windows does or even randomly, it freeze to start, most of the time the keyboard light comes for 2 seconds and the light of the disc stops, then the power light turns 3 times and everything stops. I have no ideia how to sort it out, the laptop just come again if I remove the battery of CMOS, and after 3 turns on it happens again. Another problem is when I open dota 2, my keyboard stop few keys to work.
Kikiriki
Message 3 of 4
Message 3 of 4
CMOS battery is probably dead try putting in a new one
Die CMOS-Batterie ist wahrscheinlich leer. Versuchen Sie, eine neue einzubauen
Cheers Kikiriki
Sebazdun
Message 4 of 4
Message 4 of 4
Hello
I have the same problem. Sometimes laptop starts normally sometimes you need to click few time power button. Reset RTC helps but problem come back . New RTC and bios don't solve problem. I heard that's factory problem with resistor. Maybe someone fix it ? I can pay but please show me location of this problem
3 REPLIES 3
