What pen for The medion Akoya E3221 convertible tablet?
1 REPLY 1
Stefano69
Message 1 of 2
Message 1 of 2
I have seen some posts on the topic but I am not sure there is a conclusion.
I need to buy a pen to take notes (writing) on my new convertible laptop. I have bought a generic active pen but it does not work well if not at all.
Can you suggest what is the best type of digital pen to be used?
Thanks in advance
1 REPLY 1
mats749
Message 2 of 2
Message 2 of 2
Hi @Stefano69
The laptop doesn't support active pens so you'll most likely have more luck with the passive ones,
I've seen another user has had success with the adonit mini 4 with a similar variant of the laptop. The full post can be found here
Thanks
Mats749
1 REPLY 1
